How architects run design review, coordination and RFIs directly on the drawing set.
An architect’s day runs on the drawing set. Reviewing a consultant’s sheets, marking up a floor plan, clouding a revision, answering a contractor’s question — most of it happens as markup on a PDF.
A typical project cycles a set through dozens of revisions before it’s clean enough to build from. Every pass involves is markups: someone flags an issue, someone resolves it, someone records what changed. The faster and clearer that markup moves, the fewer surprises hit the job site.
So for architects, PDF markup is where design review, coordination and revisions really get done. This page covers how that workflow runs, where it tends to break and how to keep it clean.
It connects to the Construction Document Management guide for how sets get stored and versioned, Design Review & QA/QC for the review-and-approval side, and real-time collaboration for coordinating across teams.
A spec describes the building in words; the drawing shows it. When a wall moves, a detail changes or a finish gets swapped, that decision has to show up on the drawing — or the people doing the building won’t see it.
Markups are how those decisions show up: a cloud around the revised area, a callout explaining the change, a comment tied to the exact spot on the sheet. Each one puts the decision where the rest of the team is already working.
When that markup lives on the drawing instead of in a separate comment thread or email chain, nobody has to match feedback back to a location later. The note and the place it points to are the same thing — which is the difference between a change that gets built right and one that gets missed.
Design review on a PDF means the comments live on the drawing, not in a separate list someone has to reconcile against later. Each markup sits on the exact spot it refers to, so the reviewer’s intent and the location stay together — and nothing gets lost translating notes back onto the sheet.
When review notes live in a separate document — a meeting summary, an email thread, a list someone retypes — somebody has to map each note back to the right sheet and spot later. That’s where things get missed.
Marking up the PDF skips that step. Each comment is pinned to the exact location it’s about, tracked in a list and visible to everyone with the file. Reviewers across the firm and outside it can work the same set without printing or merging copies. The Design Review & QA/QC workflow is where this runs day to day.
An architectural set never moves alone. Structural, mechanical, electrical and plumbing drawings describe the same building, and the trouble usually hides where they overlap (a beam running through a duct, a fixture with no clearance, etc.).
Some of those conflicts belong to model-based clash detection — the automated, three-dimensional check that runs across a federated model. Plenty of others get caught in 2D, on the sheets the team reads every day.
Shared markup layers let each discipline mark the same file in its own color, toggled on or off, so an architect can pull structural up, spot the conflict and flag it with a markup the engineer sees in context. It’s the 2D coordination that sits alongside clash detection, and it keeps everyone on one shared set, the single source of information that standards like ISO 19650 are built around.
A markup only helps if the next person reads it the way you meant it. Some of this is codified — the U.S. National CAD Standard sets discipline designators and layer conventions firms build on — but most teams still carry the day-to-day markup language in people’s heads: what a cloud means, which color is whose. Building that language into the tools keeps it consistent across every set, instead of relying on memory.
A shared markup standard usually pins down:
With the language built into the set, a drawing can pass through a dozen hands and still read as one coherent review
Most RFIs are questions about a specific spot on the drawings, so the clearest answer is a markup on that spot: a clouded area, a callout, a corrected detail. Answering on the sheet — instead of in a paragraph of text — cuts the back-and-forth, because the contractor sees exactly where and what without mapping your words onto the drawing themselves.
Once construction starts, the questions come back the other way. The contractor sends an RFI — a request for information asking the architect to clarify what the documents intend. They aren’t all the same, and the response that resolves each one fastest looks different:
Two things keep RFI responses from dragging out: answer in the place the question is about and make the answer clear enough that it doesn’t trigger a follow-up RFI. A clouded sheet with a specific note does both. Whatever platform logs and routes the RFI, that annotated sheet is the part that answers it. Because it travels with the set, the next person to open the file sees the question and the resolution together.
On a long project you often need to reconstruct how a drawing reached its current state. When each markup is captured with its author and a time stamp, the set carries that record itself, instead of it living in people’s memories or scattered emails.
A real project runs through months of decisions and dozens of revisions. The set that gets built is the last in a long line of versions.
When markup history is preserved — every cloud, comment and status change tracked with author and date — the set becomes a time-stamped record of the review itself. If a decision is ever questioned, the trail is right there on the sheet rather than in someone’s memory or a buried email. Comparing revisions shows exactly what changed between sets, so coordination and approvals follow the latest design intent instead of a stale copy. The drawing and document management workflow handles that revision control.
Which records count as the official, contractual project record is a separate question, governed by a team’s information-management protocols, such as the AIA’s digital practice documents (E203/G201).
Everything above runs on markup, and in Bluebeam the markup is the workspace. Architects review, redline, coordinate and respond on the same PDF set, with every markup tracked.
Every markup is logged in the Markups List with author, date and status, so a review is also a record.
Built for the way architects work, it keeps design review on the drawing instead of scattered across separate systems.
Yes. Reviewers mark up the set with clouds, callouts, comments and shapes placed directly on each sheet, tracked in a markups list and visible to everyone with the file — no printing or routing paper redlines. Multiple reviewers can work the same set at once.
They let architectural, structural and MEP teams mark one file in their own color or layer, each toggled independently. The architect can overlay any discipline to check for conflicts and flag a clash with a markup the responsible team sees in context — instead of reconciling separate redline sets by hand.
Most design-side RFIs: design coordination, design clarification, design change, scope deletion and site-condition questions all point to a specific spot on the drawings, so a clouded area, callout or corrected detail answers them directly. Schedule- and process-related RFIs are usually managed in the project platform instead.
Every markup is captured with its author, date and status, so the set carries a running record of what was flagged, changed and resolved. Comparing revisions shows what changed between versions, making the markup history a reliable internal log of the review.
Ready to run design review on the drawing? Start a free trial or see how Bluebeam is built for architects. New to the workflow? Start with the Construction Document Management guide.
